Oracle LSH Object Operations
- Execution Setup: Modify Val Status to PROD
- Execution Setup: Modify Val Status to QC
- Execution Setup: Submit
- Program: Modify Val Status to PROD
- Program: Modify Val Status to QC
- Program Instance: Modify Val Status to PROD
- Program Instance: Modify Val Status to QC
- Program Instance: Create Execution Setup
- Table: Modify Val Status to PROD
- Table: Modify Val Status to QC
- Table Instance: Modify Val Status to PROD
- Table Instance: Modify Val Status to QC
- Table Instance: BlindBreak
- Table Instance: ReadData
- Table Instance: ReadUnblind
- Work Area: Create Program Instance
- Work Area: Create Table Instance
- Work Area: Deploy (Install)
- Work Area: Modify
- Work Area: Modify Val Status to PROD
- Work Area: Modify Val Status to QC
Parent topic: Transformations and Query Builder
