Oracle LSH Object Operations
  • Load Set Instance: Modify
  • Load Set Instance: Modify Val Status to QC
  • Load Set Instance: Modify Val Status to PROD
  • Table Instance: Modify
  • Table Instance: Remove
  • Table Instance: Modify Val Status to QC
  • Table Instance: Modify Val Status to PROD
  • Work Area: Create Table Instance
  • Work Area: Create Load Set Instance
  • Work Area: Modify
  • Work Area: Modify Val Status to QC
  • Work Area: Modify Val Status to PROD
  • Work Area: Deploy (Install)
