Oracle LSH Object Operations
  • Execution Setup: Modify Val Status to PROD
  • Execution Setup: Modify Val Status to QC
  • Execution Setup: Submit
  • Program: Modify Val Status to PROD
  • Program: Modify Val Status to QC
  • Program Instance: Modify Val Status to PROD
  • Program Instance: Modify Val Status to QC
  • Program Instance: Create Execution Setup
  • Table: Modify Val Status to PROD
  • Table: Modify Val Status to QC
  • Table Instance: Modify Val Status to PROD
  • Table Instance: Modify Val Status to QC
  • Table Instance: BlindBreak
  • Table Instance: ReadData
  • Table Instance: ReadUnblind
  • Work Area: Create Program Instance
  • Work Area: Create Table Instance
  • Work Area: Deploy (Install)
  • Work Area: Modify
  • Work Area: Modify Val Status to PROD
  • Work Area: Modify Val Status to QC
