Oracle LSH Object Operations
  • Domain: Create Program
  • Execution Setup: Modify Val Status to PROD
  • Execution Setup: Modify Val Status to QC
  • Execution Setup: Submit
  • Program: Modify Val Status to PROD
  • Program: Modify Val Status to QC
  • Program: Modify
  • Program: Remove
  • Program Instance: Modify Val Status to PROD
  • Program Instance: Modify Val Status to QC
  • Program Instance: Create Execution Setup
  • Program Instance: Remove
  • Table: Modify Val Status to PROD
  • Table: Modify Val Status to QC
  • Table: Modify
  • Table: Remove
  • Work Area: Create Program Instance
