Set the default number of days of job history to display
In the Home page Data Loads, Transformations, and Validation Checks tabs, the system displays the run history for jobs for the number of days you specify in this profile. The user can toggle between this display and a display of the full history for data loads, transformations or validation check batches.
  1. Log in. See Set profiles to determine system behavior.
  2. In the Profile field, enter DMW:NUM_DAYS_PAST_RUN_HISTORY
  3. Click Find.
  4. In the Site column, enter the number of days for which you want to display job history by default. The default value is 7.
  5. In the File menu, select Save and Proceed.
