Standard Parameters
Some or all of the following standard Oracle Applications parameters are included in each function and procedure:
P_API_VERSION
(Mandatory) Enter 1.
P_INIT_MSG_LIST
(Optional) Accept the default value (FND_API.G_FALSE) to ensure that this individual API does not initialize the message list when the procedure is entered. Pass FND_API.G_TRUE to override the default behavior.
P_COMMIT
(Optional) Accept the default value (FND_API.G_FALSE) to ensure that this individual API does not commit upon completion. Pass FND_API.G_TRUE to override the default behavior.
P_VALIDATION_LEVEL
(Optional) Accept the default value to perform full validation. No other values are currently supported.
X_RETURN_STATUS
This output parameter returns the end status of the API: (S) Success, (E) Error or (U) Unexpected Error.
X_MSG_COUNT
This output parameter returns the count of error messages if the return status is other than Success.
X_MSG_DATA
This output parameter returns the text of the error message, if the message count is 1. If there are more than one messages, use cdr_pub_msg_pub.get to retrieve the messages.
Parent topic: Reference Information
