Copy a custom listing
  1. After you select a study, click Shows a table with a magnifying glassData Management in the navigation bar.
    For details on selecting a study, see Select a study.
  2. Select Custom Listing Manager from the drop-down menu to open the Custom Listing Manager tab.
  3. From the Custom Listings header in the left panel, click the The icons represents a gear.More Actions icon, then click Icon shows two sheets of paper.Copy Custom Listings.
  4. Select a project (or other study grouping).
  5. Select a model.
  6. Select one or more custom listings within the model.
  7. Click OK. The system searches the current model for the tables and columns that the selected custom listings read from.
    • If the tables or columns do not exist, the Copy operation fails with an error message.
    • If they exist but are marked Not Used in the transformation that writes to the model, the system copies the listings as disabled.
