Create discrepancies
To create a discrepancy on a data item:
  1. After you select a study, click Shows a table with a magnifying glass Data Management in the navigation bar.
    For details on selecting a study, see Select a study.
  2. Select Listings from the drop-down menu.
  3. Expand Default Listings, Custom Listings, or VC Listings. Then, expand a clinical data model from the list.
  4. Select a listing to open it.
  5. In the appropriate row, select one or more data items where you want to create a discrepancy. (You can select multiple data items if they all have the same issue.)
    Tip:
    To select multiple data items, press the Shift or Ctrl key while you select items.
  6. Right-click and select Create Discrepancy. The Create Discrepancy dialog box opens.
  7. For the State, select Open (definitely a discrepancy) or Candidate (possibly a discrepancy).
  8. In the Discrepancy field, enter details about the discrepancy (required). Then, fill in the remaining optional fields if necessary (Category and Action you want taken [for example, Ready to Send, Send to Spreadsheet, Needs Review]). To include a phrase set by you (for example, your name), select Append User Name.
  9. Click Create. Each selected data item appears with a discrepancy icon. You can also see the discrepancy icon in the second column of the listing. For details on the discrepancy icons, see View discrepancies in the Listings page.
