Default listings
Default listings shows the current data in a table.
  1. After you select a study, click Shows a table with a magnifying glass Data Management in the navigation bar.
    For details on selecting a study, see Select a study.
  2. Select Listings from the drop-down menu.
  3. Expand Default Listings in the left panel. Then, expand a clinical data model from the list.
  4. Select a listing to open it.
    To locate a listing, enter part of a listing name in the Search field and click the Icon is a magnifying glass. Search icon.
