Select a lifecycle stage
Oracle DMW opens in the lifecycle stage you used in your last session. To change it, select a different stage from the Lifecycle drop-down menu at the top of the data shown within the Home, Study Configuration, or Data Management page. The stages you can choose are:
  • Development. For studies and objects getting created or modified. When you check out an object, the new version is in Development.
  • Quality Control. For studies and objects being tested. It corresponds to UAT in InForm.
  • Production. For production data in live studies.
Depending on your account privileges, you may only have access to one or two lifecycle stages.
