Select packages
Identify the packages of functions (for example, static functions that you defined in the study configuration) that you want included in the listing.
- If not done already, open the custom listing you created in Define query details.
- Click the Selected Columns tab to open the list of packages you their path that you can add to the custom listing.
- In the Select column, select the packages you want. You can choose
one of the following:
- Leave the drop-down field over the Select column set to All.
- Select the packages you want to include and click Selected. The custom listing only includes the package you selected.
- Select the packages you do not want to include select and click Not Selected. The custom listing only includes the packages you did not select.
If necessary, use the following icons in the table toolbar to do the following:
The Idle icon holds the packages loading.
The Clear Filter icon clears a filter.
The Query by Example icon opens fields at the top of each column for you to enter the name, description, or path to locate it.
The Detach icon detaches the table from the page for you to see the whole table. Click X in the upper-right corner to close it.
- Do one of the following:
- Continue on to Define table aliases to continue defining your custom listing.
- Click OK to close the dialog box and save the custom listing with the details you entered. You can return to this procedure and search for it to continue defining it later.
Parent topic: Create a custom listing
