View the discrepancy in its source system
  1. After you select a study, click Shows a table with a magnifying glass Data Management in the navigation bar.
    For details on selecting a study, see Select a study.
  2. Select Discrepancies from the drop-down menu.
  3. Find the discrepancies you need to locate using the filters on the left panel or the top of the page. (See Find discrepancies for details on using the filters.)
  4. Select one discrepancy.
  5. From the Shows an eye icon View drop-down in the top section of the right panel, select Data in External Source.
  6. When the source system opens, log in.
