3.11.2.3.2 Create Data Source lswdbDS
Create data source lswdbDS as described. (For more information, see Oracle® E-Business Suite Software Development Kit for Java.)
The .dbc file referenced in the procedure came from the file you copied in Copy the Database Connection File.
To create data source lswdbDS:
In Step 5, enter values exactly as follows:
- Name for the datasource: lswdbDS
- JNDI Name: jdbc/lswdbDS
- Database Driver: Oracle's Driver (Thin) for Instance connections(Note that this driver is a non-XA driver.)
- Driver Class Name:
                    oracle.apps.fnd.ext.jdbc.datasource.AppsDataSource
In Step 8, enter values for your environment:
- Database name: dmwebspr (example name)
- Hostname: your_hostname
- Port: database_port_number
- DB User Name: Enter the username your created in Create the Required User dmwebs@oracle.com
- Password: Enter the password created for that user.
In Step 10, enter values exactly as follows:
- user=dmwebs@domain.com
- dbcFile=dbcFile=/scratch/u02/app/oracle/ebssdkwork/lsw250ug_DEN00RDG.dbc
Create data source lswExtSysDS and lswdbRestDS as described in the following topics.
