3.2.2 Create Database Schemas to Use with Oracle Fusion Middleware
Follow the instructions in "Creating Database Schemas" from the Oracle® Fusion Middleware Installing and Configuring the Oracle Fusion Middleware Infrastructure guide on Oracle Help Center.
Create all the schemas listed.
If you see the following message open while creating the schemas: "The selected Oracle database is not configured to use the AL32UTF8 character set. Oracle strongly recommends using the AL32UTF8 character set for databases that support Oracle Fusion Middleware," you can click Ignore to ignore it.
