5.3 Create Oracle Accounts for the Oracle DMW InForm Connector
The InForm Connector is a component of Oracle DMW. It is required to import study data and metadata from InForm. On each InForm study database, run scripts to create a read-only user account for Oracle DMW to use to access data and metadata in InForm.
The account has Select privileges on all tables and views in study accounts referenced by the InForm Connector, including metadata views, operational data views, and RDE views. This schema also has packages that facilitate the data load process.
Use the credentials of this account when you set up a database connection (remote location) in the Oracle DMW InForm configuration for each study using the InForm database. See the Oracle Health Sciences Data Management Workbench Administration Guide.
This contains topics to do the following:
