2 Install Oracle Life Sciences Data Hub
Oracle Health Sciences Data Management Workbench (Oracle DMW) is built on top of Oracle Life Sciences Data Hub (Oracle LSH). It uses the Oracle LSH database, processing engine, Distributed Processing (DP) Server, security system, defined objects, and adapters. The Oracle LSH installation includes everything required to support Oracle DMW's database.
Install Oracle LSH and its technology stack, including Oracle eBusiness Suite and Oracle Database, following instructions in the Oracle Life Sciences Data Hub Installation Guide. The original version is on the Oracle Health Sciences Life Sciences Warehouse media pack, but always check the Oracle Help Center website to see if a revised version is available: https://docs.oracle.com.
Also check My Oracle Support article 1138053.1 Oracle Life Sciences Data Hub and Oracle Clinical Development Analytics Known Install and Configuration Issues for the latest information.
The Oracle Life Sciences Data Hub Installation Guide gives instructions for downloading the software from Oracle Software Delivery Cloud and My Oracle Support into a staging area.
If you only install Oracle LSH to support DMW, you do not need to follow instructions listed in the "What's Next" chapter of the Oracle Life Sciences Data Hub Installation Guide. See the What's Next section in this document instead.
