4 Clinical data models
- In DEV and QC, run a full data model installation only to revert destructive changes
- Install and promote data models after every change
- Check out the associated transformation when you update a target data model
- Limit data model size
- Check out a data model to remove or update its business areas
- Include a SUBJECTVISIT table
- Use SDTM Identifiers for as many columns as possible
