Remove a source model from its transformations before deleting it
Recommendation: If you need to remove a data model from a study:
Check out transformations that use the data model as a source model.
For each transformation, click Add or Remove Source Models.
In the Add Model dialog box, deselect the source model that you want to delete.
Delete the data model from the study.
Parent topic: Transformations
