7 Validation checks
- Make sure to select a relevant discrepant column
- Avoid renaming columns in VC listings
- Verify the validity of a validation check batch before you copy it
- Copy valid validation checks
- Copy blinded validation checks to blinded tables
- Do not remove a source table from a validation check
- Do not use staging tables as a source for validation checks
