Delete a library clinical data model
To delete a clinical data model, select it in the Library Data Model pane and You must have the Remove Model privilege.
Click the Navigation icon
at the top of any page and then click Library.
Select the project (or whatever study categories are called in your company) that includes the model.
Under Filter Library Data Models:, enter part or all of the model name and press Enter. The system lists all models whose name contains the string you typed.
Select a model, either by clicking it or by using the Down arrow and then pressing Enter.
Click Check Out if it is not already checked out.
Click the
Delete Clinical Data Model icon.
It is possible to delete a library model that has been used in a study. This has no effect on the study model.
Parent topic: Create a library clinical data model
