Explicitly mark as Not Used
After you select a study, click the Study Configuration icon
from the navigation bar to open the Clinical Data Model tab.
- Click the Transformation tab to view the source and target tables.
Select a single table or column.
- Select Mark as Not Used from the Mark drop-down in the table or column pane.
Parent topic: Mark target tables and columns as Not Used
