Install a validation check batch
After creating or modifying a validation check batch, you must install it to make it usable. See What happens during installation? for details.
Validation check batch installation fails if there are destructive changes in the model such as the removal of a column or table that the validation check reads. See Why does it say Upgrade Required? for details.
Click the Study Configuration main menu icon
from the navigation bar. Then, click the Validation Checks
tab.
Select one or more validation check batches, then select one of the following from the Install drop-down list:
Install Batch upgrades all tables and programs and does not delete any data.
Full Install drops and replaces all tables and programs, deleting all data. Full installation is not available in the Production lifecycle.
The installation options are available only if all selected batches are installable:- The Version and the Installable Version must be the same.
- See Validation check batch installation requirements for details.
To see the updated job status in the Install Status field, click the
Refresh icon.
To see the log file:
Go to the Home page, Validation Checks tab.
From the Model drop-down list, select the source clinical data model.
In the VC Batch Name column, select the batch.
Click the icon in the Install Job Log column in the same row.
Parent topic: Create validation checks
