Map at the clinical data model level
For details on mapping at the clinical data model level, see this video:
Click the Study Configuration icon from the navigation bar. Then click the Transformations tab.
In the Data Models pane on the left, select the clinical data model the transformation will write data into.
The system displays its tables in both the Target Tables and Source Tables panes so that you can use the target tables as a source for side models.
Click the Add or Remove Source Model icon in the Source Tables pane.
- Select one or more models to feed data into the transformation's target model.
Tip:
Reference models are listed after the study models. See Set up reference data. - For each, select the Can Trigger checkbox if you want the completion of a job updating data in the source model to trigger the execution of this transformation.
- Click Save.
Tip:
If many people are working on the same transformation, Use side transformations.Next: Map at the table level.
A tilde (~) displayed next to an input model means the model was deleted while the transformation was checked in. When you check out the transformation, the deleted model is no longer displayed at all. - Select one or more models to feed data into the transformation's target model.
Parent topic: Set up data transformations
