- Study Setup Guide
- Load data and run jobs
- Run validation check batches and view run history
- Run a validation check batch
You must run validation checks as a batch.
- Go to the
Home page, Validation Checks tab. - Select a validation check batch and click the
Submit Job icon.Tip:
The Submit Job icon does not appear if the validation check batch is not installed. Check the Installed Status.
If the installation status of a validation check batch is Warning, you may still be able to run the batch. Check the installation log file. If the status is Warning because one of the source tables is not used in the current study, the batch runs without input from that table.
- Enter values:
Submission Mode: Select one:
Full includes data deletion. Use Full mode only if you are confident that you are reloading all current data.
Incremental is faster and does not include data deletion.
Force Execution: Select to run the job even though the source data currency, parameter values, and the version number of the program(s) have not changed since the last run. The system uses Full mode regardless of the Submission Mode setting. Full mode includes data deletion.
If not selected and all the conditions are the same as the last run, the system does not execute the job and returns a status of Success.
Submission Type: Select:
Immediate to run the job once, as soon as possible.
Scheduled to set up a regular schedule.
Deferred to run the job once, at a future time.
Trigger Downstream Transformations and Validation Checks: Select this checkbox if you want the system to detect all transformations and validation checks set up for this data model and all others that come after it, and submit them sequentially.
This option appears only if the validation check batch is set up to allow it.
Click the
Refresh icon at any time for an update.
To check the log file, click the icon in the Log column.
Parent topic: Run validation check batches and view run history
