Study Setup Guide Load data and run jobs Load data from InForm Schedule InForm data loads in Production Schedule InForm data loads in Production After you select a study, click the Study Configuration icon from the navigation bar. Then click the Clinical Data Model tab. Select Production from the Lifecycle drop-down at the top of the page. Click the Suspend icon. Install the model if it has not already been installed in Production. Select Production under Study Lifecycle in the table below. Select the Schedule Production Data Load checkbox. Note: If you do not check this box, it is possible to enter Fetch Frequency and click Save, but the system does not actually schedule the load. Specify a Fetch Frequency: the number of minutes between automatic data loads. Note: A data load will not start until the previous one completes. Save. Click the Resume icon. The first scheduled data load starts immediately. See InForm data isn't loading? for more information (if necessary). Parent topic: Load data from InForm
