Set up data blinding in tables
Click the Study Configuration icon
from the navigation bar. Then click the Clinical Data Models tab.
Select the model and click Check Out.
Select the table.
Set blinding attributes:
Blinded: Select if the table may ever contain any sensitive data that should be hidden.
Blinding Type (available only if Blinded is selected): Select one:
Table: Select to hide all data in the table, then click OK.
Column: Select to mask all values in one or more columns, or in cells where data in the row meets conditions you specify, then click OK.
Then select one column, click the
Modify icon and specify the masking value.
Tip:
Enclose the value in single quotes.
The default masking values are
xxxxx
for character data,99999
for numeric data, and15-AUG-3501
for dates.To blind data only in cells that meet certain conditions, specify the conditions; see Specify masking attributes for a column.
Row: Select to hide certain rows in their entirety.
Blinding Criteria: Click the
Modify Blinding Criteria icon to specify which rows should be hidden. See Use the Expression Builder for details.
Back to Set up clinical data models
