Transformation installation requirements
The transformation's status must be Complete. If it is Incomplete, at least one table or column in the target model is neither mapped nor marked Not Used.
All source and target tables must be installable. (See Clinical data model installation requirements.)
If it has a custom program, the program must be installable. A program is not installable if it does not have source code or source and target tables.
All expressions must have valid code.
Parent topic: Installation requirements
