View discrepancies created by a validation check
- Click the Data Management icon
from the navigation bar and click Listings to open the Listings
page. - Select the source clinical data model.
- Select Validation Checks from the bottom of the left pane.
- Expand the node for the batch containing the validation check.
- Select the validation check.
Parent topic: Create validation checks
