Assign Clinical One operations to roles
You'll need to grant some roles appropriate permissions to use the Clinical One features integrated into DMW.
The following permissions (operations) are necessary for roles that configure and maintain the Clinical One data exchange with DMW.
To learn about assigning operations to roles, see Assign roles to operations.
Table 3-1 Clinical One Object Operations
Operation | Objective |
Configure Clinical One |
Load Clinical One metadata | Activates the ![]() |
Parent topic: Set up Clinical One data exchange
