Compare flags, tags, and categories
The following table compares flags, tags, and categories. All are available for use in any study.
Table 1-2 Flags, Tags, and Categories
Object Applied To Applied By Used as Filter? Has Multiple States? Used for
Flag
Records
User or validation check. InForm flag assignments are imported and can be viewed but not changed.
Yes
Yes
Data management
Tag
Discrepancies
User or validation check, via actions
Yes
No, but can be used to create discrepancy substates
Discrepancy management
Category
Discrepancies, Validation Checks, Flags
Validation check or user
Yes
No
Discrepancy and data management
