4 Use filters to find data and discrepancies
This section has information on the standard (quick) and advanced filters available in the Listings pages and in the Discrepancies page. Quick filters include a list of fields where you can enter data or select options from a drop-down list. Advanced filters include numerous categories with operators for you to build a filter formula from a list of drop-down options (depending on the criteria and operators you use). You can use the quick and advanced filters together, if necessary.
Tip:
By default, you cannot view canceled or closed discrepancies unless you use the Discrepancy State field in the filter. For more details, see Create a new filter.
For more details, see this video:
