View the full record containing a discrepancy
After you select a study, click
Data Management in the navigation bar.
For details on selecting a study, see Select a study from the Home page. -
Select Discrepancies from the drop-down menu.
Find the discrepancies you need to locate using the filters on the left panel or the top of the page. (See Find discrepancies for details on using the filters.)
- Select one discrepancy.
- From the
View drop-down in the top section of the right panel, select Full
Record to open the Full Record dialog box.
- To see a particular column, enter part of the column name in the Search field
and click
to locate it.
- (Optional) Select Show Only Changes to see only items with different current and original data values.
- Click
to close the Full Record dialog box.
Parent topic: See more information about a discrepancy
