View transformation job history
As described in Run transformations and view run history, you access transformation through the Transformations tab on the Home page. Transformations are displayed by the name of their target clinical data model.
  • To view table transformations, click a transformation's node.
  • To view run history and pending jobs, select a transformation in the upper pane.
  • To view log files, click the icon in the column for the type of job:
    • Log: The most recent manually submitted job.
    • Triggered Job Log: The most recent triggered job.
    • Install Job Log: The most recent installation of the transformation.
