Select internal InForm tables and views for data transformations
Click the Study Configuration icon
from the navigation bar. Then click the Clinical Data Models
tab.
Select Development from the Lifecycle drop-down at the top of the page.
Select the clinical data model and click Check Out.
Click the
Select InForm Operational Data and Metadata Tables icon.
The system displays all InForm tables and views alphabetically. To sort by type, click the heading of the Internal Data Model column. Your administrator makes the default selections. Gray tables and views are required.
Select and deselect until you have selected the tables and views you want for this study.
Save.
After you load metadata and data and install, you can see the internal tables and views in the Default Listings page.
Next: Load InForm metadata.
Parent topic: Create a clinical data model for InForm data
