List of adapters
DMW uses the following adapters. Other adapters appear in the Oracle LSH UI, but they are used only in LSH.
The InForm Family Adapter includes:
InForm Data is required for users to set up an InForm clinical data model, including loading data from InForm and scheduling data loading.
InForm Metadata is required for users to set up an InForm clinical data model, including loading InForm metadata.
Oracle Export is required for users to create, modify, or install a clinical data model that is set up for exporting data in an Oracle Export file. It is also required to run the job to create the Oracle Export file.
The Oracle Family Adapter is not required.
Oracle Tables and Views is not supported in this release.
PLSQL This adapter is used internally. Users do not need access to it.
SAS Export is required for users to create, modify, or install a clinical data model that is set up for exporting data in a SAS file. It is also required to run the job to create the SAS file.
The SAS Family Adapter includes:
SAS is required for users who upload SAS files to create table metadata in clinical data models.
SAS Program is required to upload SAS programs or to run a transformation or validation check that uses a SAS custom program.
Text Export is required for users to create, modify, or install a clinical data model that is set up for exporting data in a text file. It is also required to run the job to create the text file.
The Text Family Adapter/Text is required for users who create an input file clinical data model of type Text.
The Visualization Adapter/Generic Visualization is required to view data using a visualization tool.
Parent topic: Assign user groups to adapters for technology privileges
