Oracle LSH Object Operations
- Application Area: Create Work Area
- Application Area: View
- Domain: Create Data Model
- Domain: Create Load Set
- Domain: Create Variable
- Domain: View
- Load Set: View
- Load Set: Modify
- Load Set: Modify Val Status to QC
- Load Set: Modify Val Status to PROD
- Table: View
- Table: Modify
- Table Instance: Modify
- Table Instance: Remove
- Table Instance: Modify Val Status to QC
- Table Instance: Modify Val Status to PROD
- Variable: Modify
- Variable: Modify Val Status to QC
- Variable: Modify Val Status to PROD
- Work Area: Create Table Instance
- Work Area: Create Load Set Instance
- Work Area: Modify
- Work Area: Modify Val Status to QC
- Work Area: Modify Val Status to PROD
- Work Area: Delete
- Work Area: Deploy (Install)
- Work Area: View
Parent topic: Clinical Data Models and Query Builder
