Oracle LSH Object Operations
- Application Area: Manage Security
- Application Area: Create Work Area
- Application Area: Create Program
- Domain: Create SubDomain
- Domain: Modify
- Domain: Delete
- Domain: Manage Security
- Domain: Create Load Set
- Domain: Create Variable
- Domain: Create Program
- Domain: Create Data Model
- Domain: Create Transformation Map
- Table Instance: Manage Security
- Work Area: Manage Security
- Work Area: Create Table Instance
- Work Area: Create Load Set Instance
- Work Area: Modify
- Work Area: Modify Val Status to QC
- Work Area: Modify Val Status to PROD
- Work Area: Delete
- Work Area: Deploy (Install)
- Work Area: Create Program Instance
- Variable: Modify
- Variable: Modify Val Status to QC
- Variable: Modify Val Status to PROD
Parent topic: Clinical Data Models and Query Builder
