Oracle LSH Object Operations
- Domain: Create Program
- Execution Setup: Modify Val Status to PROD
- Execution Setup: Modify Val Status to QC
- Execution Setup: Submit
- Program: Modify Val Status to PROD
- Program: Modify Val Status to QC
- Program: Modify
- Program: Remove
- Program Instance: Modify Val Status to PROD
- Program Instance: Modify Val Status to QC
- Program Instance: Create Execution Setup
- Program Instance: Remove
- Table: Modify Val Status to PROD
- Table: Modify Val Status to QC
- Table: Modify
- Table: Remove
- Work Area: Create Program Instance
Parent topic: Validation Checks
