Check in Objects and Copy them into a Different Domain
Use this overloaded API to copy objects into a Domain and check them in if they are checked out, before copying.
Name
CDR_PUB_DF_DOMAIN.CopyObjectsIntoDomain
Signature
PROCEDURE COPYOBJECTSINTODOMAIN(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_CDRBASEOBJCOLL  IN OUT    CDR_BASE_OBJ_COLL,
  PI_CDRTARGETCONTAINEROBJECT  IN OUT    CDR_BASE_OBJ_TYPE,
  PI_CHECKINFLAG  IN    VARCHAR
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_CDRBASEOBJCOLL (Mandatory) This is a collection of CDR_BASE_OBJ_TYPEs. For each object that you want to copy, initialize a CDR_BASE_OBJ_TYPE and then extend the collection.
    The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
  • PI_CDRTARGETCONTAINEROBJECT (Mandatory) This is a parameter of CDR_BASE_OBJ_TYPE and contains basic naming details about the Domain into which you want copy objects.
    The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER, and OBJECT_VERSION_NUMBER).
  • PI_CHECKINFLAG (Mandatory) Enter $YESNO$YES if you want to check in the copied objects, if they are checked out, and $YESNO$NO if you do not want to check in the copied objects.
