Copy Objects into a Work Area
Use this API to copy one or more objects into a Work Area.
Name
CDR_PUB_DF_WORKAREA.CopyObjectsIntoWA
Signature
PROCEDURE COPYOBJECTSINTOWA(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_CDRPRREFOBJCOLL  IN    CDR_PRREF_OBJ_COLL,
  PI_CDRTARGETCONTAINEROBJECT  IN OUT    CDR_PRREF_OBJ_TYPE,
  PI_CHECKINFLAG  IN    VARCHAR,
  PI_COPYPRGASSGNMT  IN    VARCHAR
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_CDRPRREFOBJCOLL (Mandatory) This is a collection of Prref objects that contains information about the instance objects you want to copy into the Work Area.
    Provide values for the attributes COMPANY_ID, OBJ_ID, OBJ_VER, PRREF_ID, PRREF_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER,OBJECT_VERSION_NUMBER for each instance object. The PRREF_ID and PRREF_VER attributes store the hierarchy information for objects.
  • PI_CDRTARGETCONTAINEROBJECT (Mandatory) This is a parameter of Prref object type that describes the target Work Area.
    Enter values for the attributes COMPANY_ID, OBJ_ID, OBJ_VER, PRREF_ID, PRREF_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER,OBJECT_VERSION_NUMBER.
  • PI_CHECKINFLAG (Mandatory) Enter 'Y' for this flag.
  • PI_COPYPRGASSGNMT (Optional) This parameter is not applicable.
