Create an Adapter Domain
Use this API to create an Adapter Domain.
Name
CDR_PUB_ATK_ADAPTER.CreateAdapterDomain
Signature
PROCEDURE CREATEADAPTERDOMAIN(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_ADAPTERDOMAINNAMING  IN OUT    CDR_NAMING_VERSION_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_ADAPTERDOMAINNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values for the Adapter Domain that you are creating. For OBJECT_TYPE_RC enter $OBJTYPES$ADAPTERDOMAIN.
The following attributes are required: COMPANY_ID,NAME
