Create a Planned Output
Use this API to create a Planned Output.
Name
CDR_PUB_DF_PLANNED_OUTPUT.CreatePlannedOutput
Signature
PROCEDURE CREATEPLANNEDOUTPUT(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_SOURCECDRNAMING  IN OUT    CDR_NAMING_VERSION_OBJ_TYPE,
  PI_PLANNEDOUTPUTOBJTYPE  IN OUT    CDR_PLANNEDOUTPUT_OBJ_TYPE,
  PI_DEFCLASSIFICATIONCOLL  IN    CDR_CLASSIFICATIONS_COLL
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_SOURCECDRNAMING (Mandatory) This is a parameter of type CDR_NAMING_VERSIONS_OBJ_TYPE.
    The following attributes are required: COMPANY_ID, OBJECT_TYPE_RC, NAME, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER, OWNING_LOCATION_RC, OBJECT_SUBTYPE_ID, DESCRIPTION, REF_COMPANY_ID, REF_OBJ_ID, REF_OBJ_VER.
    For OBJECT_TYPE_RC enter $OBJTYPES$PLANNEDOUT.
  • PI_PLANNEDOUTPUTOBJTYPE (Mandatory) This is a parameter of table type CDR_PLANNEDOUTPUT_OBJ_TYPE.
    You need to pass the following attributes: COMPANY_ID, OBJ_ID, OBJ_VER,TITLE, POSITION, FILEREF, FILE_NAME, PRIMARY_FLAG_RC, ERROR_FILE_FLAG_RC, REQ_FILE_FLAG_RC.
    For the POSITION attribute, use the GETNEWPOSITIONNUMBER API.
  • PI_DEFCLASSIFICATIONCOLL (Optional) By default the new PLANNED OUTPUT is classified according to the subtype you assigned it in the CDR_NAMING_VERSION_OBJ_TYPE.
    If you want to override the default classifications for one or more classification levels, use this parameter. This is a collection of CDR_CLA_OBJ_TYPEs, which have 5 attributes, including CLA_LEVEL_ID and CLASSIFICATION_ID.
    If you want the definition to inherit its classifications for a particular level from its parent, enter the classification level ID and, for the CLASSIFICATION_ID, enter 0 (zero).
    If you want to explicitly assign one or more terms for a particular level, initialize a CDR_CLA_OBJ_TYPE for each term, entering the classification level ID and, for the CLASSIFICATION_ID, the term ID.
    If you want to use a Parameter to classify the actual output, use the PAR attributes to identify the Parameter. The Parameter's list of values must be based on a classification hierarchy level.
