Create a Work Area
Use this API to create a new Work Area.
Name
CDR_PUB_DF_WORKAREA.CreateWorkArea
Signature
PROCEDURE CREATEWORKAREA(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_SOURCECDRNAMING  IN OUT    CDR_NAMING_VERSION_OBJ_TYPE,
  PIO_WORKAREAOBJTYPE  IN OUT    CDR_WORKAREA_OBJ_TYPE,
  PI_DEFCLASSIFICATIONCOLL  IN    CDR_CLASSIFICATIONS_COLL
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_WORKAREAOBJTYPE (Mandatory) This is a parameter of table type CDR_WORKAREA_OBJ_TYPE that contains object attributes specific to Work Areas. Enter values for the Work Area that you want to create.
    The following attributes are required: COMPANY_ID, OBJ_ID, OBJ_VER. For OBJECT_TYPE_RC enter $OBJTYPES$WORKAREA. By default, new Work Areas receive a Usage Intent value of Development.
  • PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Work Area that you want to create.
    The following attributes are required: COMPANY_ID,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER,OBJECT_TYPE_RC. FOR OBJECT_TYPE_RC ENTER $OBJTYPES$WORKAREA.
  • PI_DEFCLASSIFICATIONCOLL (Optional) By default the new Work Area is classified according to the subtype you assigned it in the CDR_NAMING_VERSION_OBJ_TYPE.
    If you want to override the default classifications for one or more classification levels, use this parameter. This is a collection of CDR_CLA_OBJ_TYPEs, which have 5 attributes, including CLA_LEVEL_ID and CLASSIFICATION_ID. If you want the Work Area to inherit its classifications for a particular level from its parent Application Area, enter the classification level ID and, for the CLASSIFICATION_ID, enter 0 (zero). If you want to explicitly assign one or more terms for a particular level, initialize a CDR_CLA_OBJ_TYPE for each term, entering the classification level ID and, for the CLASSIFICATION_ID, the term ID. The PAR_ attributes are not relevant to Work Areas. Do not enter any values for them.
