Create a Workflow Transition
Use this API to create a Workflow transition. A Workflow transition connects two Workflow activities.
Name
CDR_PUB_DF_WORKFLOW.CreateWfTransition
Signature
PROCEDURE CREATEWFTRANSITION(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_SOURCECDRNAMING  IN OUT    CDR_NAMING_VERSION_OBJ_TYPE,
  PI_CDRWFTRANSITION  IN OUT    CDR_WMG_TRANS_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSIONS_OBJ_TYPE that contains CDR Naming Version attributes.
    For OBJECT_TYPE_RC enter $OBJTYPES$WORKFLOW if you are creating a definition only; $OBJTYPES$WORKFLOWREF if you are creating an instance of an existing definition; and also if you are creating a new definition and an instance of it.
  • PI_CDRWFTRANSITION The Object ID and Version of the two Workflow activities being connected through this transition should be populated in the CDR_WMG_TRANS_OBJ_TYPE.
    In the CONDITION_RC attribute, specify the activity condition based on which the workflow transitions to the other specified activity.
    The possible values are $WFTRANSITIONS$NONE, $WFTRANSITIONS$SUCCESS, $WFTRANSITIONS$ERROR,$WFTRANSITIONS$WARNING
