Download a Job Output BLOB
Use this API to download a job output BLOB.
Name
CDR_PUB_EXE_EXTERNAL.DownloadTempBlob
Signature
FUNCTION DOWNLOADTEMPBLOB(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  PI_NOBJID  IN    NUMBER,
  PO_VFILENAME  OUT    VARCHAR2
) RETURN BLOB;
Return
Type BLOB
Description returns the output file as a BLOB.
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_NOBJID (Mandatory) Enter the tmp_blob_id of the job output LOB. You can use the following query to get this ID:
    SELECT tmp_blob_id FROM cdr_temp_blobs_v WHERE job_id = pi_nJobId;
  • PO_VFILENAME (Mandatory) This Out parameter contains the file name of the downloaded LOB file.
