Get Checkout Properties
Use this API to retrieve the checkout status and implicit checkout property of a specified object.
Name
CDR_PUB_DF_NAMING_UTIL.GetChkoutProp
Signature
PROCEDURE GETCHKOUTPROP(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PI_COMPID  IN    NUMBER,
  PI_OBJID  IN    NUMBER,
  PO_CHKOUTSTATUS  OUT    VARCHAR2,
  PO_CHKIMPLPROP  OUT    VARCHAR2
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_COMPID (Mandatory) Enter the COMPANY_ID of the given object.
  • PI_OBJID (Mandatory) Enter the OBJ_ID of the given object.
  • PO_CHKOUTSTATUS This is an output parameter. It returns the checkout status of the given object
  • PO_CHKIMPLPROP This is an output parameter. It returns the implicit checkout property of the given object.
