Mark Column Maps Not Used
Use this API to mark column mappings as Not Used.
Name
DME_PUB_XFORM_MAP.MarkColumnMapNotUsed
Signature
PROCEDURE MARKCOLUMNMAPNOTUSED
(P_API_VERSION IN VARCHAR2,  P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE,  P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,  X_RETURN_STATUS OUT NOCOPY VARCHAR2,  X_MSG_COUNT OUT NOCOPY NUMBER,  X_MSG_DATA OUT NOCOPY VARCHAR2,  PI_MAPOBJID IN CDR_NAMING_VERSIONS.OBJ_ID%TYPE,  PI_MAPOBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
  • PI_MAPOBJID (Mandatory). Enter object Id of Column Transformation Map.
  • PI_MAPOBJVER (Mandatory). Enter object Version of Column Transformation Map.
