Modify a Domain
Use this API to modify a Domain.
Name
CDR_PUB_DF_DOMAIN.ModifyDomain
Signature
PROCEDURE MODIFYDOMAIN(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_SOURCECDRNAMING  IN OUT    CDR_NAMING_VERSION_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Domain and enter new values for the attributes you want to modify. The COMPANY_ID, OBJ_ID and OBJ_VER of the domain to be modified should be initialized.
Use separate APIs for modifying the validation status and the version label: CDR_PUB_VL_VALIDATION. UPDATEVALSTATUS and CDR_PUB_DF_NAMING. UPDATEVERSIONLABEL.
