Modify an Execution Setup Parameter
Use this API to modify the parameters of an Execution Setup.
Name
CDR_PUB_DF_EXECUTIONSETUP.ModifYesParameters
Signature
PROCEDURE MODIFYESPARAMETERS(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_PARAMETERCOLL  IN OUT    CDR_PARAMETER_COLL
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_PARAMETERCOLL (Mandatory) This is a collection of cdr_parameter_coll. Enter the values for parameters you want to change.
The attributes you can change are: read_only_flag_rc, mandatory_flag_rc, and visible_flag_rc. Enter $yesno$yes for yes, and $yesno$no for no.
