Modify a Load Set
Use this API to modify a Load Set definition or instance. You can change the name, description, or version label.
If you are modifying a definition, you must first check it out.
Name
CDR_PUB_DF_LOADSET.ModifyLoadSet
Signature
PROCEDURE MODIFYLOADSET(
  P_API_VERSION  IN    NUMBER,
  P_INIT_MSG_LIST  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_COMMIT  IN    VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
  P_VALIDATION_LEVEL  IN    NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
  X_RETURN_STATUS  OUT    VARCHAR2,
  X_MSG_COUNT  OUT    NUMBER,
  X_MSG_DATA  OUT    VARCHAR2,
  PIO_CDRNAMING  IN OUT    CDR_NAMING_VERSION_OBJ_TYPE
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
PIO_CDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Load Set and enter new values for the attributes you want to modify. All attributes are required.
